Hi All
Noticed this the other day whilst bored and mucking about
Say you have a chase with a BPM of 65 you have it chosen and you use the left hand roller wheel to speed up and slow down if you use it slowly it holds the speed but if you hit enter it defaults back to 120bpm (the console default)
if you let the roller go from a position off centre it puts the chase back to 120bpm also
slightly annoying that it doesnt reset back to the chase speed you have set prior to using the roller or stay at the speed you have set on the roller either way defaulting back to 120 surely needs addressing
mikey
