Hi, I have problem with Hog3 PC v3.2.2 (3337). The software is crashed when I try to go to the Control Panel. Using soft at my laptop Windows7.32-bit. Images of fatal error here. Please somebody help me))))
Try this: Quit Hog3PC Navigate to C:\Users\YOURUSERNAME\AppData\Roaming\Flying Pig Systems\Hog 3PC Delete the persistent folder Launch Hog3PC and try the control panel again
I have C:\Users\vitalik\Documents\Flying Pig Systems\Hog 3PC\
The folder Hog 3PC сontains two folders Logs and Shows. When I delete Folder Hog 3PC, at the next start of software it is appears again. And the same critical error appear!
Vitali, you are not going into the right directory. You might have to turn on the option in your computer to "show hidden folders". That way you can see the app data folder under users.
[QUOTE=c_muenchow;58422]Vitali, you are not going into the right directory. You might have to turn on the option in your computer to "show hidden folders". That way you can see the app data folder under users.
Ok....I find the right directory...and delete it....and againe at the next start of software it is appears. And the same critical error appear!
Try disabling all of your network adapters in Windows. Right click and disable all of them including firewire and bluetooth. Either the application is having a rough time accessing one or all of their configurations or their is a lower level issue on your PC that might require a clean install of the OS.
