question about control of MIDI HOG3PC.
hello, I have question about control of MIDI HOG3PC.
I have HOG3PC and MIDI Controller Behringer BCF2000. what management functions are available to me in such a combination? As far as I know, and HOG3PC and BCF2000 MIDI support Show Command.
When I tried to connect I get: instead Play Next Cue Play Cue №, I could not operate the faders,. This is software limitation, or I had not figured in the Manual Instruction?
I use version 3.1.8, may be the latest version of the problem does not arise?
Alex. Russia
  • Basically you have two major forms of Midi communication that Hog3PC can listen to. 1) System exclusive messages (SYSEX) and Midi Notes. More than likely you are going to want to approach control using midi notes. Mapping faders and encoders is not going to work as we only allow mapping to button actions. For more details check out section 28.3 of the Wholehog Manual "Working with MIDI Notes".
    Note: Midi note functionality was added in v3.1.7 but is probably most stable and most fully functional in v3.2.2
