Hoping that it might be possible to add a few lines of text to this document.
Spent a while yesterday trying to update a DP8000 software with an IPC console and also a laptop.
It's helpful to know that if you power off the DP8000 and power up holding the center and left buttons on the DP8000 if forces a linux boot which can help in certain instances.
The DP8000 i was using would not upload the software from either the console or laptop prior to doing this.
Also it would be clearer if you had a section for IPC consoles also.
Thanks again C
