I am having a strange issue with one of my cuelists dropping out when advancing through cues. I am using a Hog PC on this job with 3.2.2 and a Fader wing. I use one list as a macro trigger cuelist which starts the other lists at the same time. I do the same thing on my RHFB and it works fine. I have checked the syntax, reprogrammed the cues, and I can't figure out why it keeps releasing that cuelist (located on fader 10). Also, the release on Fader 10 is more of a cut than a fade. I have checked the options to make sure that the fade time is right but it just doesn't fade on release which could be linked to the other dropout issue.
Any ideas?
thanks,
Eric
