Bug: Merge Show - Copy/Paste Minor Bug
Noticed a minor bug in the Merge Show feature on Hog III PC (latest build). While copying and pasting hob libraries from my desktop to the library section while in the program I chose "Resolve" so that there was a copy of the new and old library. I then deleted the older version of the library. The bug occurs when I try to rename the new library (such as uncommon_v4(2) to uncommon_v4) - in the description field the newer library number reverts to the older library number of the file that was deleted. This resolves itself if the program is restarted.
Not super important, but it is a bug, figure you should know about it! :D
