DP8000 crash The dispaly only show about list: Init:NO inittab file found Init:Entering runlevel :3 Init:no more processes left in this runlevel I/O board disconnected I/O board connected
Which software version are you using? The software reload guide should work 100%. Make sure if you are on a Hog3 that you are loaded into a show when doing the network boot. Most people skip over that. Also, if you are on v3.2.3 you will need make sure the boot server option is check in the control panel on the console.
