Basic Assignment Help
I won a HOG3PC setup with a DMX widget and would like to set it up to replace an old NSI board. I only have 24 active channels on the old board and I currently talk only to ASI dimmer packs.
My issue is that I can not seem to find a way to select a "fixture" that would allow me to just select dimming and assign the DMX channels that are currently being used.
Would anyone be able to direct me to a resolution? The online manuals have just made things more confusing than they need to be. I do have connectivity from the PC to the panels as when I add some fixtures, some lights will at least come on.
Thank you in advance....
Jim
