Editor Window Aggregation Priority
Whilst it is possible to open an editor window for a cue and set the desired fixture type priority and even to be able to close the editor and return to it with the fixtures in the same order - using the editors next and back buttons to move through the list's cues resets the priority (and what fixture types are collapsed or not).
This seems to happen in both compact and longwinded mode.
Is it not possible to store or modify a default fixture type priority?
Or use the order from the fixture window globally?
I appreciate that the order of some windows (eg output) can be saved in a view but that doesn't work here.
