How do you adjust cuelist FX rate with release end
Hi All
How do you adjust your cuelist effect rate which or not on a master? And when using ADD Release end cue, which I use on Pan/tilt FX and colour FX.
In previous Hog3 builds (3.19) I adjusted the rate by touching the list make the adjustment and then sweep away, so I didnt release the list.
On the new builds this doesn't seem possible since the selection methode changed when I sweep away now, I select / launch other cuelists or release the current list. (the selection is black in the current builds, in previous builds it was clear so something changed)
The work around I use now, make 2 views 1 with guard and 1 with guard dissabled.
Just wondering if there are other ways of makeing these rate adjustments without having to puch more buttons :06:
