I have tried to record storbe effects for my Elation power spot 250's into the efects pallete and It won't record them... Can you just not do that, or am I doing something wrong? I am running HOG3 pc
When recording strobe into the effects pallete I've always done it under the effects engine with Intensity set to Sine, and then I just played with the effects length, speed, etc until i found the perfect strobe. Also fanning the the intensity while doing this can get you some pretty neat effects.
