Clay Paky Alpha Spot 1200
Does anyone know which mode the clay Paky alpha spot 1200 fixture should be set to to work correctly with the current fixture profile available.
The fixture patch requires 23 DMX channels but the manual for the fixture is suggesting either stnd,16B or extended mode none of which are 23 channel with a few options that can be switched on or off in the fixture.
Don't currently have the fixture so cannot test.
Regards C
