Deleting Cuelist from a Master BUG from v3.2.0 onwards
Hello,
I have found a very irritating bug on my Wholehog 3 and traced it back to v3.2.0. The problem does not occur in v3.1.9. It exists also in 3.2.3. The issue is also present on Hog3PC.
When holding down CHOOSE and pressing DELETE to clear a Master fader, the options bar that appears at the bottom of the right hand screen locks in place so you cannot get back to the default bar.
In version 3.1.9, the behaviour is as you would expect. When holding CHOOSE the bar appears and as soon as DELETE is pressed, the Master is empty and the bar restores to default.
Please can this be fixed in your next release?
Cheers
Colin
