Hi, Can someone tell or point me in the direction of part numbers for the older Blue 04 x DMX output superwidget. I need to replace one of the DMX input connectors which has been damaged.
The replacement circuit board for a Super Widget is HES Service Part Number 80030109EF.
If it's just the 5-pin XLR jack that's damaged, it's probably cheaper to replace the connector. HES service can do the repair, or you can do it yourself if you have a repair tech who is comfortable soldering on multi-layer circuit boards.
