DP 2000 is dead!!! Help!!!
Hi,everyone,
We need help with our DP 2000. The problem occured while it was repaired after unexpected shutdown. After the switching on, it wrights next message (IMG 0074):
(c) 2002 FP S All Rights Reserved
DMX 2000 Processor Node
MAC address 00-90-A1-01-14-14
Flash image invalid
Initialising network...
After this it begins searching of the software server. Fnd it can't find it (IMG0075, 0076) We've connected it with WH3 and HOG3 PC with the latest software. And nothing happens. Please anybody help!!! Thank you.
Parents
  • A couple of things:
    - DP2000 cannot run v3.2.0 or greater
    - Do a FULL INSTALL of 3.1.9 on your console
    - After the full install simply launch a new show (do not change any settings)
    - Connect the DP2000 to your console using a CAT 5 Xover cable
    - BEFORE powering on the DP2000 hold down the front three buttons
    - Apply power to the DP2000 while holding the three buttons and you should see the display read forcing software reload. This may take 2 or three tries.
    If you continue to have trouble you might want to try installing Hog 3PC on your computer and force a software load onto the DP2000 from you PC in the same manner.
Reply
Children
No Data
