Adjust size title bar above fader 1>10
I dont know if this has been a discussion before but...
What do you think about the idea to make the titlebar of the cuelist above fader 1 thru 10 adjustable.
for example:
In some titlebars I just use the word: "MAIN" because its my main cue list, in the field below the title bar I can type the name of the cue's.
In some other titlebars I want to type a longer word or even 2 or more words as cuelist name. Often the second word is not visible because it simply wont fit in the small title bar.
So, if you can have the option to change the titlebar from 1 line to multiple lines you wont have this problem anymore.
Idea?
