Anyone out there have their server process crash while adjusting lamps in the programmer? If so is there a way to re start the process without restarting the desk?
try pressing PIG + OPEN + BACKSPACE (its a bit like CTRL ALT DEL on a PC) you should get a pop up window with all the process's that are running or have stopped, you can then right click on these process's and KILL then or RESTART then, this is a very quick way of getting things up and running after a crash or stall.
Have had the same problem on the ipc when I changed pan/tilt of 100 heads the server crashed due to the load, especially when I did fast changes with the track ball.
With 50 heads there was a noticeable lag but 100 heads was just to much for the old hardware.
