DNS Setting?
I'm using HOG PC v. 3.1.9 and I'm having a bit of trouble wirelessly networking my Tablet. Hard wired it finds the show no problem. Also if I log off with the server and log back in, my Tablet will find the show wirelessly. I'm using Static IP Addresses, the only setting I'm not sure about is the DNS and if that matters?
I'm using a switch of course and a WAP. I've checked all IPs.
The really weird thing is I had no trouble on my friends show a few weeks ago.
Thanks in advance for any help. :1zhelp:
Parents
  • Just ot add to this topic (even though I know its been solved) there are two numbers that you should always keep an eye on when building any kind of network where things need to talk to each other- the IP address and the subnet mask.
    Your subnet should be identical across all items of your network. 255.255.255.0 is usually a good place to start and allows for 254 unique devices to talk to each other. Your IP address scheme should follow a pattern similar to something like 192.168.1.X.
Reply
Children
No Data
