I am working on a show with Benoit Richard. We have multiple servers on one large Hognetwork. Each stage has a laptop running Hog3PC as a server with a DP8K, and each kit is on a different port number. There is also a network drive inline. Ben uses a Full Boar and I am using a Hog 3 console. We also both use a tablet PC as a remote. We are running v3.2.3. Every device has a static IP address.
Ben has his FullBoar set up as a 2nd server which allows him to backup the show from his console onto the network drive without having to go to the laptop server. For my Hog3 console, there are a couple of issues.
Issue1) My console is unable to connect to the network drive. All the settings and password are right. Ben even tried it out, but it does not want to connect.
Issue2) At times, there is a small hiccup in the WiFi connection, even when the signal strength is full. We figure it is probably interference from another device in the same frequency. Anyways, what I see on the Tablet is a message saying the main server dropped and the other one took over....as it should. The laptop server never really goes down. Whenever I see this message, I check the network window, and it shows everything still running. Now the HogPC on the Tablet, which is a client, is still able to program, however it will not update the cues. So I just log off and back on, and everything is fine.
Here's the weird part. At the end of the day, I log off the tablet and the console and shut them down, leaving only the laptop server running. Then I go to the laptop server and run a backup of the show, quit, and power down. The next day I come in and boot the show up, everything looks fine except the fact that all the groups are missing. I have all my cues from the previous night, all my views, and even the patch is still intact, but no groups to be found.
Now, it just so happens, when this came about, we also had a problem with the show's backup file. It was missing too, but we believe it was due to a time/date error on the laptop. My quick fix was to merge the groups from a older backup. This would allow me to keep my cues and get my groups back. The weird part was that when the merge completed, the original groups that were missing came back and the merged groups were added in as .5 groups. So I just deleted the merged groups and all was well.
What do you guys think?
