3.2.4 very slow fanning offset and encoders
System:
Hog 3PC running on Windows XP Pro
Super Widget
1 x Programming Wing
3 x Playback Wing
SW: 3.2.4
The lagging Encoder Issue is known but it seems that It get even worse on 3.2.4
Dialing in a Colour or Position with the encoders first will have a very laggy movement (it's also a bit steppy).
After a few seconds it gets back to fluent response.
Closing Pallet Windows did not change anything.
Fanning the offset of an effect is really spain in the *** as you don't see any live changes. In that Moment when you start fanning the offset the effect stops and gets back to running when you stop fanning.
At least it's possible to bring the effect to the desired look, but it takes way longer than before, and my feeling is that all this responsiveness was still better in 3.2.3.
I'm pretty sure that this is not new to anybody, just want to make sure that this issue is well known.
Best
Rolf
