ok so we play in this club that now has 10 Chauvet Colorpalettes.. when i go to the library to add the fixtures there is 3 different choices.. 1) Colorpalette 27ch cell, 2) Colorpalette master, 3) Colorpalette 6ch mode.. or something like that.. now if i run it in 6ch mode then its easy to work with and no problems... BUT if i want to run it in 27ch mode im having issues... my question is are the cell and master supposed to be combined when you patch them?? or am i missing something here... im so confused :confused:
thats what i thought.. but how do i do that?? ive never had to do that with other fixtures ive come across or used... first time for everything i guess
Just patch the master and then patch the cells right after. Then address your fixture to where you patched the master. Looking at the profile for the cells you can actually just add and patch RGB LEDs instead of the cell fixtures because they are exactly the same.
