Jarag 5 programming
Does anyone have any experience programming Jarag 5 fixtures. I'm starting a show in a couple of days. I've read there are built in effects but I'm going to have to busk with these. Any tips would be welcomed.
:headbang:
  • Hi,
    Depending on what mode these units are set to which i think are 6 channel,
    25 Channel and 31 Channel is probably going to determine how you program these fixtures.
    The most common mode is i see is 31 channel which uses 25 standard desk channels and a 6 channel control fixture which is available in the current fixture library.
    Attached is a current jarag manual if you have not got it.
    Getting the effects to work is a little tricky and will take a bit of work.
    Finding out which mode the fixtures are set to is probably a good starting point.
    best C
