DP 8000 not outputting DMX
Hey
Today I upgraded my iPC from 3.1.9 to 3.2.3 with a full install from the XPE image after backing up my shows. Everything went fine, though I did have to force my external DP to upgrade the firmware.
The iPC and the DP will see each other, but the DP won't output any DMX. I've checked the settings, it's getting it's IP settings from the iPCs DHCP server and is setup exactly as before. All the Artnet/sACN outputs are off and not in use.
Everything else is set as before. I'm going to try and reinstall the software, as I've seen a post that seems to have a similar issue, but with the internal DP.
Any suggestions would be welcome though.
Thanks.
