networking a hog ipc
Hey, so I have Hog IPC and I am wanting to network it so I can use my laptop to control it. We have a Road Hog that can't be networked which is odd because it is the only model that can't be and we got a IPC as a back up but it can be networked so I am wanting to make a switch and make the roadhog the backup. So I don't know how to make the ipc network so I am wanting someone to help walk me thru that.
Jesse
  • There are a couple of tutorials at the link below that may help about networking consoles and setting up a DHCP server.
    www.highend.com/support/training/wholehogtutorials.asp
    Starting in section 12.2 of the manual also explains it better than I can write here.
    Look it over and give us a call at High End if you have questions.
    You will need to be familiar with getting to the Windows Network Connections on your PC and making sure only the one being used is the only one enabled.
