Acetivate fixture builder
I would like to create a new fixture with fixture builder , but When i Open setup---->patch the botton fixture builder Is off .
How can i do???
Best regards
  • xmrdieselx
    you should be able to access the fixture builder in the patch window.
    Open the fixture window (setup, patch or alternatively Open fixture) click on the fixture builder soft button in the upper toolbar. You should get the fixture builder opened in the left hand screen after clicking on the ok button of the warning pop up window you get after clicking on the fixture builder soft button.
    Hope this helps
  • [QUOTE=bellons;62634]xmrdieselx
    Hope this helps
    Hi thanks for your answer
    The problem is i'm not able to push the botton is total grehow how can i do it?
  • The button shouldn't be grayed out at all. Start a new show and see if it makes any difference!
