Qwash 260 led
Anyone else successfully program/operate these guys on a hog 3? I had a hell o a time today getting a profile that would work. Looks like the profiles all have intensity as 1 but it is supposed to start with pan?
I finally got the basic mode to work but I then had major playback issues...
1-8 @ full record master 1 enter
Clear programmer and trigger playback
Only unit 1 turns on...
Second issue I found:
Select 1-8 and select position palette and nothing happens but then if you barely nudge the pan or tilt encoder it then snaps to the position in the pallet...
Also nothing but unit 1 dimmer at full would record to a playback...
Needless to say my brain is fried and I can't wait for my 4!
