Hello Ive been programming shows on a hog 3 and I find it annoying that if I record merge thru a range of cue numbers it adds any whole number cues that are missing. I totally get that if i record a range of cues it creates them but once you select merge it should not. I am doing theatrical shows with cue list around 500-600 cues long and I often end up with missing whole numbers when things change. Typying all the cue numbers in a range in using + is a pain when I need to merge into a bunch of cues.
