Installing video card drivers into xpE
Is there a series of keystrokes that will allow me to check if video drivers are loaded. Maybe like: (ex.ctrl s f3, or something.) I cannot get my second video card to work after changing motherboard and video card. This is an ipc that had an advantech motherboard put in it at high end. The video card and motherboard were freaking out and so i replaced them. Now no 2nd video is being detected.
Please help if you can.
  • Hello, it may be the BIOS settings are not correct, you can see the link below for the BIOS document.
    www.flyingpig.com/support/hog3/documents/HogiPCBios.pdf
    You may also try a Full Install of the software as this is needed after swapping out hardware. I am not sure what was changed where so this may be necessary if hardware was replaced.
    If the console was recently at High End for repair, please contact me at mitch_peebles@highend.com with the console serial number etc so I can look at the repair and what options may be available.
