Is there a way to remove an address from an entire cuelist?
I need an address to either be removed or at least be able to set it's value to 0 in the entire list.
The address is on in every cue I need it to be off so I can control it manually on faders.
Just curious if there is a quick way of doing this instead of going through each cue and turning it off.
Help appreciated
