HTP fader
I have the question of HOG3
Example:
Master1 HTP Fader
Cue1 :
Dimmer ch.1 FULL
Master2 LTP (Default)
Cue1 :
Dimmer Ch.1 Full
Dimmer Ch.2 Full
Master2 GO > Release
Ch.1 doesn't do the fade-out though Ch2 does the fade-out.
When Master1 is set to LTP and the fader is raised with the manual, the same effect as LTP is achieved.
However, when the release All (Pig + Release) is done, it is released.
The release ALL is frequently used and I want to use it by the LTP fader.
Is there a solution?
Thanks,:headbang:
