Event monitor "warning" - b3414 3.2.5
Setup:
Hog3PC setup as Server (with Programming/Playback wing)
DP8000
Hog 3 as client
I was having a couple of oddities with the console and opened the Event Monitor to see if anything was odd. I was greeted with a CONTINUOUS scrolling of the following:
PB Boss Timing - Warning - Sleep took 34ms, exceeding frame period by 4ms
And it DOES NOT stop. I clear the log and it starts back up. The node listed is the DP8000.
Is there anything I should be worried about???
Parents Reply Children
No Data
