PATCHING ATOMIC SCROLLERS
This my be something silly but when patching scrollers I used the Atomic Strobe + Scroller which is only one channel so do I therefore have to patch another Atomic Strobe... But is it correct that the strobes are a separate fixture number than the scroller?
  • Atomic Scrollers is a fixture with 2 patchpoints, one for the Atomic one for the scroller.
    In the patch window where the universes are shown you choose which part you would like to patch. This ist the same with VL5 or Scroller+Dimmer
    Then you only have one user number for the scroller and Atomic
    You can also patch 1 atomic and from the generics a scroller, then you will have 2 different fixtures each with its own user number
