Ok, i would suggest that your tablet only works as a client. So turn off the server on that HOG-PC and give it a seperate Net-ID, so your laptop #1 and your tablet #2. Check that they are set to the same port (standard is 6600) Also check that you are in the same adress-range and sub-net. Firewall and Virusscanners should be off. If this all fine you should see the show running on your laptop as a network-show and you could connect to it.
