Midi commands H3 into Qlab
has anybody successfully been able to fire LOAD and GO commands in qlab from a comment macro on a Full Boar? I have 12 different cue lists representing different songs. many with multiple media files in them. Ideally when I play into a cue on my desk I would like to fire the qlab list at the same time. Any help, suggestions, or examples would be greatly appreciated. I am using a midi uno device between my laptop and the desk.
  • What kind of Midicommand is used for these Commands in Qlab?
    If you know that you can enter this midi-command (in HEX) as a comment-macro.
    In H3 there is a little limit of the length of the midi-string, so that for example setting a Rosendahl MIF3 to a certain timecode could not be done (Sys-Ex commands). But Load and Go should just be Notes i think
    IN H4 it works also withe the Sys-Ex Commands
