Curious if anyone has had the touch membrane on a IPC ELO touch screen float to one side or the other, making part of the screen unusable. If so were you able to open the front bezel on the monitor and slide it back into position, or did you have to send it off for repair? Thanks.
I had this problem a few years ago. You can fix it yourself but it's a real pain in the ass. As I recall, there are some plastic tabs that hold the glass and touch membrane in place but the glass can slip. The biggest problem you are going to have is that once you fix it, the next time it's in a road case bouncing down the road the same thing is going to happen again.
