Hey y'all. Thanks for viewing my other post. One other issue I'm having is for some reason I can't program any macros on the Hog3PC. I've rechecked the manual and looked online but I can't seem to be able to input and commands. Is there an "Enable Macros" option that I'm missing somewhere or something? Thanks.
Programmer and playback wings. I'm just sure where to input the commands. When I select a macro from the palette and hit set it just lets me rename it and I haven't been able to set one in the cell in the cuelist window. I know it's something stupid that I'm missing. I'd like to be able to run virtual lists/scenes from the palettes and then write a macro to release each one so I don't have to pig release everything.
To record for example macro 1 press the following keys: * Record * Macro * 1
Now do your actions, when you are done press *pig+macro
Your macro had been recorded. To open and edit do it like with any other directory item Have a look in the manual :-) It is all in there... And the manual comes within the software ;)
Thanks a lot. When I tried it like the manual said it didn't seem to be working so I figured I was leaving out a step or something. I appreciate the help.
