Hello all. Thanks to everyone who answered my post before. I was much appreciated. I have another query. My Hog 3 PC has been working fine on the desktop that I have on set and now I need to have it work on my laptop. I'm using an HP Touchscreen laptop running Windows 8 specifically for the program. I have been able to network it with the Programmer and Playback wing that I have but for some reason the widgets are not networking. I have used Hog 3 PC on a Lenovo Touchscreen with Windows 8 with the same hardware so I know it's possible but I can't figure out where I'm going wrong with this one. I have uninstalled and reinstalled the widget drivers a few times, tried different USB cables, and different USB ports and I can't seem to get it working. My device manager sees the Widgets as HighEnd Widgets also. Any suggestions would be awesome. Thanks to you all. Cheers.
You may just need to add it into the Internal DP's settings. In Setup/Network select your DP and hit settings. On Widgets Output tab, you can select your widget from the pulldown. If nothing is showing up there, you have other issues.
