Wholehog 3 crush system((((
Hello! Wholehog3 control this problem before the show went off both the screen and the flashing all choise!!! Hanging reboots the console show any buttons does not listen! That it can be???standing version 3.1.9
  • If the buttons are all flashing at startup, that means the mother-board has lost connection to the front-panel.
    You should open up your desk and check the cables to be sure the connections are good.
    If they are OK and the problem persists, then you may have a problem on the mother-board or front-panel PCB that requires service.
    Hope this helps. :)
