Editing a Cue Inside a Cuelist
I feel like this should be something stupid simple, but I cannot figure out what I'm doing wrong.
Say I accidentally update cue 1 inside cuelist 1 with fixture 1 at a value of 100.
1000 cues recorded later, I realize I messed up cuelist 1. In fact, I don't want fixture one in cuelist 1 at all. How do I remove fixture 1's existence inside cuelist 1?
Example... I record a value inside my house lights cue list. That value affects all of my movers. I want to remove the values that affect my movers that got accidentally recorded in my house lights cue list.
Any help would be appreciated.
  • Good question charlie.
    Several ways I know of,
    First Way...
    In the Cuelist window press View Cue button.
    Use NEXT and BACK in window if you need to get to your cue.
    Once in your cue press Edit.
    Select only that fixture, then press Knockout.
    Close editing screen and Save changes on exiting.
    Second way (typically how I do it)...
    In programmer grab only that fixture.
    Press touch.
    Press Record, then Remove (bottom of right screen), List x, CUE x, Enter.
    Omit List if List is Chosen
