I'm running a small show on a laptop, but cannot figure out how to hold a key on the virtual control panel, IE recording a desktop (holding [record] and hitting the soft key on the screen) to one of the soft keys on the (default) top left monitor. Thanks
I'm running Hog3 on an MBP. I had to go in to the parallels menu and enable the keyboard shortcuts using the virtual break button and the virtual insert button to rename everything. Convoluted but it works I suppose.
To hold down a single key and make another selection, simply press and hold SHIFT on your computer keyboard when you click the a button. As long as you are holding shift, this key (and subsequent keys) will remain held down. You can then click on another button, cell, or encoder to access further functions
