Hog 3PC No Vitrual DP8000
Bit of an odd one. I just bought a single (blue) widget and it works fine on my Hog III console when added via the network window.
However, I've tried to use it on two different PCs, one running Vista 32bit and one Windows 7 Pro 32bit. When I go into the network window on Hog 3pc, there is no virtual DP8000 for me to select and then map the widgets to. It just comes up empty with no DPs found.
'Run Internal DP' is selected in start up. I've tried uninstalling, re-downloading and reinstalling Hog 3pc V:3.26 several times but no luck.
Am I missing something?
