Punting Hog 3: Changing timing
I've set up my console roughly as suggested in this thread: www.controlbooth.com/threads/hog-3-and-4-busking-ideas.32523/
The one problem I'm having is changing my cue list timings. I haven't gotten to the point of writing the macro because I can't get the keystrokes themselves to work.
Say I have a look on Cuelist 100 that I've named "Yel/Blu" that I want to change to a 0 count.
In the above referenced thread I would turn guard on in my cuelist window, tap cuelist 100, then activate a keystroke macro that typed "cue 1>10 time 0"
When I attempt to do this manually the name of the cuelist (Yel/Blu) comes up in the command line instead of the number (100) and as soon as I hit "time" the command line turns red.
any suggestions as to what I might be doing wrong?
Is there a work around so that I don't have to manually type in each cuelist number to change times?
Is there a way to create a global time change so as to have all my cuelists change at once?
Thanks much for any assistance!
