our hog3 is running ver 3.1.9 dp2000, and now I got dp8000 and I'm having a problem in upgrading the board. I already download the next ver which is ver 3.2.0 and I burn it on cd but the board is still looking for fpspkg files.
You need to use the FULL INSTALL (.iso) file. This has to be burned as an image to a CD-R, making it a boot-able disc.
Once that is done, make sure the disc is in the CD drive. Power on the console while holding the ENTER button down. This should give you a menu at the Hog III boot screen. Select the option for Full Install. and Enter, and then confirm.
