IPC faders & screen
Hi Guys
I have an IPC that i would like to extend his life a bit more but now i have two broken faders that i need to replace, can anyone advice on any alternative faders i can use as i live in the other side of the world and would like to see if i can find any after market faders i can replace the broken one with.
and another question is im board of the graphic card for the screen two problem and im willing to use just one screen and was successful to move all the GUI windows to the left screen but the playback fader part keeps going back to screen two after restart, is there a way to pin the fader label to screen one.
Thank you.
  • You can purchase replacement faders if you need from HES.
    www.highend.com/hes-support/service-parts
    90405330EF
    FADER
    The console is based on a two screen system. If the graphics card is not initializing the adapter correctly. Check the BIOS settings of the computer. See link below:
    www2.highend.com/support/controllers/documents/HogiPCBios.pdf
