Effect speed change in cue's - BUG!
Hey all,
im using hog 3 console
this is the bug:
1st cue: sharpy doing circal effect at rate 5
2nd cue: sharpy doing circal effct at rate 10
press go to the 1st cue, everything ok
press go for the 2nd cue, the sharpy loss the effect path for a second and then go back to the original path
how i record:
a simpale as is - program circal effect at 5, record 1st cuw, rotate rate wheel to 10 and record 2nd cue.
I try every mathod posible to solve this unprofesional bag and no luck.
the effect should change the speed smothly and not changing the path in the crossfade
its happend on all the effect parameters, not only on the position.
its should work smooth like if i change the effect speed of the cuelist manualy after i hold choose.
this bug massing a lot of exiting looks for me.
if someone have an idea, please, im a 10 years hog user and cant find a solution for that.
thanks
Amir
