Hi
the issue is that the lights in the bump buttons do not indicate that a pre-existing sequence exists when you enter <REC ALL> or <REC SEL> allowing you to inadvertently overwrite a sequence. The lights on those memories with static scenes correctly light dimly but those on memories with sequences flash the same as blank memories.
This action is confirmed on both a real console and in Virtual Smartfade ML.
