Can anyone explain how to set up Colorblasts and Colorblazes in a Smartfade 96?
Hello,
Could you be more specific about which specific Colorblast and Colorblaze fixtures you mean? There are several effective ways to set these up on the SmartFade console, depending on how you plan to use them. Generally speaking, I'd recommend making a Memory for each color that you want to mix, along with a control for the intensity, if necessary. Knowing which fixtures you have would help us tease this out.
Matt Pumplin
Technical Support Specialist
