SmartFade ML & D60s Setup?
Having some questions on how to properly set up 9 ETC D60 Vivid's on RGB+SF with SmartFade ML and how to program looping colour effects with SmartSoft.
Able to control them together but not individually.
  • What have you tried so far? How do you currently have them set up?
    If they're all working together all the time then the fixtures might all have the same DMX address.
    The controls and effects are applied to the currently "Selected" (bright device button) devices, so make sure you only select the lights you want to be in that particular effect.
