Good morning
its possivel program chanels to a step on the stack, without using the memorys.
same like the express console
chanel 1 at 30%
chanel 3 at 45%
rec to step 1 or cue 1
i am saying this, because i want to use the memory separate
Good morning
chanel 1 at 30%
chanel 3 at 45%
Hi
It need memorize in Memory fader also in this case.
1. Push Rec seq and choose Stack or Sequence.
2. Where Rec mem is pushed, carry out a channel mode (1-24, 25-48) change level setup.
3. If Rec mem is released, it will become memory of memory fader.
4. It record as a sequence step 1 at the same time memory fader will memorize, if bump button of memory fader is pushed.
This work is repeated.
Was it help now?
Best regards,
Kani
Currently this is only possible on the SmartFade ML, and not the other SmartFades.
On SmartFade ML:
On the other members of the SmartFade family you can't do this - however there is no reason why you couldn't set up the 'stack' memories on the last few pages, leaving the first few pages for your master-fade memories.
