Memory playback
Having trouble with my memory faders. I have a video attached explaining whats going on. Any help would be appreciated.
Alfonso.
http://youtu.be/cCMtKNg42SQ
  • This is normal - to solve your problem turn GO mode on, then press the bump button for each memory BEFORE you bring up the memory fader. This will send out the parameters for that memory other than intensity so will set your device colors etc - then the memory fader will just fade intensity.
    Also - you may want to turn off Memory Rubberband in the console settings so that when bringing a memory fader down the parameters won't scroll back to the last memory state.
    Hope that helps.
